Spams 2021 SS(svarčika sapnis)
Kā pareizi metināt mk3 sliekšņus?
Uzmetināt ar makrofleksu
26%
izņemt tepiķi un pārdot kā nepabeigtu projektu
26%
Paverdzināt Gati par pāris čīzīšiem
22%
Nododot tolmetā
Šis jautājums parāda ka tu tomēr esi švaks šī foruma lasītājs
Total votes: 23
Re: Spams 2021 SS(svarčika sapnis)
Post by Jujubokar » 28.09.2021, 20:54
28.09.2021, 14:42
No kā var rasties melna želejīga masa dīzeļa degvielas tvertnē?
Tank contamination known as diesel sludge is an algae-like substance in which cells adhere to each other on the tank surface or at the fuel water interface. The sludge settles to the bottom of a fuel tank and can clog filters when the vehicle is fueled.
What causes black algae in diesel fuel?
Loss of sulfur in the fuel (so there's nothing to keep it from growing) makes any free water in the tank a breeding ground for this fuel "algae". ... Just as little as a quarter-inch layer of water at the bottom is plenty enough for microbes and diesel fuel algae to grow and thrive.
Post by arniks8 » 28.09.2021, 23:25
principā tāda paša stila recaro kā m2, ne?
https://www.facebook.com/marketplace/it ... 5%7D%22%7D
Post by fokume » 29.09.2021, 00:31
Kad brauc pa provinci un pie kādas mājas pamani b3.
https://vm.tiktok.com/ZMRWb7Fp7/
Post by Nordik » 29.09.2021, 07:54
Миша
Post by Миша » 29.09.2021, 07:54
Power is nothing withoutImage
Post by arniks8 » 29.09.2021, 10:16
Labs :D
Post by fokume » 29.09.2021, 10:41
Ekskluzīvs un neatkartojams
Post by povar » 29.09.2021, 11:06
Trendīgi, man patīk
Post by mikimiki » 29.09.2021, 11:24
Vistas ir tik foršas
Post by fokume » 29.09.2021, 11:25
Stabiņvistas vai ūdens vistas?
Post by mikimiki » 29.09.2021, 11:31
vojīša vistiņas
Post by mikimiki » 29.09.2021, 11:32
Volvo stūrī norvozi pīpē
Post by fokume » 29.09.2021, 13:47
Check engine vairāk neies apskati
FSI vaginatori taisa suiciidus
Post by mdz » 29.09.2021, 13:58
24.09.2021, 07:28
Easy, 2 stundas pīpējot
Kā domā, bez pacēlāja/bedres cilvēcīgi viņu varētu nocelt? Jāsamaina primārajai asij gultņi, bet negribu papist weekendu servisā, labāk pie sevis siltā garāžā, kur var mētāties bez termiņa :D
Pēdējais variants ko apsveru, izraut viņu ar visu motoru, to točna uz zemes var. Pie vienām sāpēm vel zondi samainītu.
