DODmanSOJU wrote:HELP -
Vai kādam ir pieejama kāda programma, kurā varētu redzēt bremžu trubu garumus?
būtu ļoti pateicīgs, ja varētu dabūt visus 8 izmērus priekš sekojošā auto -
VW Golf mk2, 1991. gads, 1.6td (SB dzinējs ar 59kw), aizmugurē trumuļi.
<1986 with rear proportioning valve
Front Left 550mm
Front Right 1300mm
Mid Left 2350mm
Mid Right 2450mm
Rear Left 400mm
Rear Right 1300mm
Axle Left 600mm
Axle Right 600mm
<1986 without rear proportioning valve
Front Left 550mm
Front Right 1300mm
Mid Left 2500mm
Mid Right 3480mm
Axle Left 600mm
Axle Right 600mm
1987 with rear proportioning valve
Front Left 550mm
Front Right 1300mm
Mid Left 2350mm
Mid Right 2450mm
Rear Left 400mm
Rear Right 1300mm
Axle Left 600mm
Axle Right 600mm
<1987 without rear proportioning valve
Front Left 550mm
Front Right 1300mm
Mid Left 2480mm
Mid Right 3480mm
Axle Left 600mm
Axle Right 600mm
1988 with rear proportioning valve
Front Left 550mm
Front Right 1300mm
Mid Left 2350mm
Mid Right 2440mm
Rear Left 400mm
Rear Right 1300mm
Axle Left 600mm
Axle Right 600mm
1988 without rear proportioning valve
Front Left 550mm
Front Right 1300mm
Mid Left 2480mm
Mid Right 3470mm
Axle Left 600mm
Axle Right 600mm
1989 with rear proportioning valve and rear disc
Front Left 535mm
Front Right 1290mm
Mid Left 2350mm
Mid Right 2440mm
Rear Left 390mm
Rear Right 1230mm
Axle Left 465mm
Axle Right 465mm
1989 with rear proportioning valve and 180mm drums
Front Left 535mm
Front Right 1290mm
Mid Left 2350mm
Mid Right 2440mm
Rear Left 390mm
Rear Right 1230mm
Axle Left 565mm
Axle Right 565mm
1989 with rear proportioning valve and 200mm drums
Front Left 535mm
Front Right 1290mm
Mid Left 2350mm
Mid Right 2440mm
Rear Left 390mm
Rear Right 1230mm
Axle Left 575mm
Axle Right 575mm
1989 without rear proportioning valve and 180mm drums
Front Left 535mm
Front Right 1290mm
Mid Left 2480mm
Mid Right 3470mm
Axle Left 565mm
Axle Right 565mm
1989 without rear proportioning valve and 200mm drums
Front Left 535mm
Front Right 1290mm
Mid Left 2480mm
Mid Right 3470mm
Axle Left 575mm
Axle Right 575mm
1990-1992 (up to VIN ending with 1GL990000) with rear proportioning valve and rear disc
Front Left 625mm
Front Right 1290mm
Mid Left 2350mm
Mid Right 2440mm
Rear Left 390mm
Rear Right 1230mm
Axle Left 465mm
Axle Right 465mm
1990-1992 (up to VIN ending with 1GL990000) with rear proportioning valve and drums
Front Left 625mm
Front Right 1290mm
Mid Left 2350mm
Mid Right 2440mm
Rear Left 390mm
Rear Right 1230mm
Axle Left 565mm
Axle Right 565mm
1990-1992 (VIN ending with 1GM000001 and up) with rear proportioning valve and rear disc
Front Left 625mm
Front Right 1290mm
Mid Left 2350mm
Mid Right 2440mm
Rear Left 390mm
Rear Right 1230mm
Axle Left 635mm
Axle Right 758mm
1990-1992 (VIN ending with 1GM000001 and up) with rear proportioning valve and drums
Front Left 625mm
Front Right 1290mm
Mid Left 2350mm
Mid Right 2440mm
Rear Left 390mm
Rear Right 1230mm
Axle Left 745mm
Axle Right 875mm
1990-1992 (up to VIN ending with 1GL990000) without rear proportioning valve and drums
Front Left 625mm
Front Right 1290mm
Mid Left 2480mm
Mid Right 3555mm
Axle Left 565mm
Axle Right 565mm
1990-1992 (VIN ending with 1GM000001 and up) without rear proportioning valve and drums
Front Left 625mm
Front Right 1290mm
Mid Left 2480mm
Mid Right 3555mm
Axle Left 745mm
Axle Right 875mm
