kludas
kludas
VAG-COM Version: Release 311.2-N
Chassis Type: 1H - VW G/J/V Mk3
Scan: 01,02,03,08,15,25,56
Address 01 -------------------------------------------------------
Controller: 037 906 024 AG
Component: DIGIFANT 1.7 1576PMC
2 Faults Found:
00518 - Throttle Position Sensor (G69)
34-10 - No Malfunction Detected - Intermittent
00524 - Knock Sensor 1 (G61)
Readiness: N/A
Skipping Address 15-Airbags
End -------------------------------------------------------
lambda factor 0.87 at 858RPM 5.0gradi Ign. Timing
tauta varetu palidzet,ka si te tulkojas..???sarkanaja krasa iekrasoti!
2 Faults Found:
Readiness: N/A
neapzinati...zemu lidoju
pats labakais jau tas ka to tikai vienreiz izmet..nu pirmo reiz...a otro nav....Mārtiņš wrote:1) Jaapaarbauda vadi/savienojumi uz mineetajiem deveejiem;
2) Jaaiztiira un jaaadaptee droseljklape;
3) Ja nepaliidz - jaamaina bojaataas detaljas.
P.S. Peec nodzeeshanas kljuudas uzreiz iemet atpakalj?
Varbut zini vai 1.8Gt (mono) ir iespejams caur VAG-COM visu peetiit?Mārtiņš wrote:Tieshi taa - paaris dienas pabraukaa, tad lasi atkal. Ja paraadaas, tadtochna jaameklee vaina. Citu kljuudu nav?
P.S. A tas teksts ir dabuuts ar Copy/Paste no VAG-COM`a?
Buu piemeta, kludas neradija, citu ar neko nelava darit!?
Varbut kads cits zin?
